Voltage Blocking Diode
HI
i am designing a db with indication lamps on the fuses to indicate a blown fuse. i am connecting them with voltage blocking diodes to avoid one blown LED showing on every fuse LEDs. my question is can i get a diode module that, say has 20 diodes, i am not too sure how these look, but i assume i can get this type of arrangement. has anyone here dealt with the situation like this.
comments are really appreciated
RE: Voltage Blocking Diode
You can find lots of such modules if you google 'lamp test'. One source is here http://www.aps-systems.ch/en/Funktionsbaustein.htm
What is a 'db' BTW? Dash-board? And, please, use capital letters where you were taught to do so.
Gunnar Englund
www.gke.org
