UG-39 (b) before (c) checking for opening reinforcement?
I am dealing with cylindrical vessels (inner diameter=d) with flat unstayed covers at both ends. These covers have central openings (finished diameter=dop). Following UG-39 (b), I already found no reinforcement was needed in cases dop<=0.5 d; but, for the same vessel and cover thicknesses, could I simply assume the same in cases where dop>0.5 d, without the need for calculations stated by UG-39 (c)?
Thanks in advance,
J.I.G.C.
RE: UG-39 (b) before (c) checking for opening reinforcement?
Your question is unclear (or are you requesting whether you can dismiss a code rule?).
If the diameter of the opening exceeds one half the head diameter, then UG-39(c) is of application, and you cannot a priori assume the rules it contains are satisfied.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
