Double fed Induction Generators
Double fed induction generators can be used to generate a fixed frequency with a variable shaft speed by driving the rotor with a variable frequency.
What are the limits for the mechanical speed range over which this type of generator can be used? most wind powered units that I have sen still use a gear box to step the speed up before driving the double fed induction generator.
Best regards,
Mark.
Best regards,
Mark.
Mark Empson
L M Photonics Ltd
RE: Double fed Induction Generators
Muthu
www.edison.co.in
