Floating Suction Design
I need to design a floating suction and want to establish how buoyant the float should be. We are designing for a tank of 5.9m Dia x 7.5m High with only one single swivel elbow. This will mean that the when the tank is filled to the top the float will be submerged so I do not want to make the float lighter than it should be.
As the float is not required to lift the entire weight of the pipe I would like to know what percentage of the weight it should be designed to lift. Either a rule of thumb or pointers into design calculations would be appreciated.
RE: Floating Suction Design
