isolation valves under relief valves
thread1203-147792: BYPASS, ISOLATION OF PSV WHILE UNIT IN SERVICE
i have seen block valves (isolation valves)between vessels and PSV's for many years in the GOM used by many large oil companies so if there are leagal issues with that they would have been addressed.however these vessels usually have PSH (pressure safety high) sensors also in place which will shut the inflo or cause blowdown to protect the vessel these are usually set @ or around MAWP
RE: isolation valves under relief valves
Within the USA there are different regulations depending upon the industry. An isolation valve is not generally permitted under the safety valve in fired boiler applications. Even in this case some states permit deviation.
Within many hydrocarbon applications the isolation valve is permitted except that the valve must be car-sealed or locked open. In the event that the valve is serviced, perhaps some requirements apply to operators monitoring the vessel. I have not checked lately and perhaps the safety shutdown applications must apply.
Also, these things change.
regards,
Everybody forgets about keeping the valve 'manned' while closed for maintenance. Massively inportant -- KABOOM's are expensive and tend to maime/kill people.
