Control for PRV in EPANET
I want to set my PRV to maintain 75 psi in the lower closed area with no reservoir.  Upstream the pressure can be 120 to 135 psi.
How would I word the Control?
RE: Control for PRV in EPANET
Do not use 'Control': (Control is for switch logic, such as if reservoir full then turn the pump off.)
use a 'Valve' as a link between two nodes
set type to 'PRV' (there are also psv, pbv, fcv, tcv and gpv.)
put setting at 75, also set downstrean node elevations correctly.
the program will set the pressure at 75 and adjust flow until the equations balance.  If there is not enough pressure upstream to provide the needed flow there will be an error.
Hydrae
