Ordinate and Linear Dimensions
I'm checking some engineering drawings and notice that the engineer has a mix of Ordinate and Linear Dimensioning schemes defining his geometry. Is this normal practice? I mention he should stick with one or the other. He used linear scheme to define the centerline of the part, then used ordinate for the other. What are your thoughts? I can upload an example if you need to look at my issue.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 XP Pro SP 3 (32-bit)
Xeon CPU 2.53 GHz 3.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
RE: Ordinate and Linear Dimensions
I don't like to mix them. Consistency makes good dwgs IMO. I have had cases when a customer required mix dims per their own contract drawings, but rare.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
You need to be more specific.  I will, on occasion, mix the two.  If nearly everything can be measured from common datums save for a small hole pattern or a bend line, I will add regular dimensions in the same view as the ordinates.  Just don't have anything double-dimensioned, is all.
I don't think there's chapter-and-verse anywhere that explicitly prohibits a dual scheme.
Martinet
macduff,
   Is the drawing clear and unambiguous?
   If so, I would say it is okay.  I have mixed the two on occasion.
               JHG
Thanks for the feedback all. I'm just going to leave it alone for now.
Mechanical Designer
