Annoying squeaking sound
Hi guys,
I designed a friction-based blocking system. The system basically consists of a shoulder bolt rubbing in a slotted plastic piece. The plastic is Nylatron GSM, and the shoulder bolt is standard steel.
The system works well, except after a certain amount of cycles, there's a very annoying squeaking sound coming from the friction between the plastic slot and the shoulder bolt. I put Jig-A-Loo on the shoulder bolt and the squeaking disappeared, but only for some time. The problem is that I can't tell the customers to put jig-a-loo in there every time it squeaks! I have to use food-grade grease, but I don't want to cause it would decrease the friction force a lot plus it would gather dust...
I cannot change the plastic and ran out of ideas for stopping this squeaking.
Does anyone of you guys could help me?
Thanks a lot
RE: Annoying squeaking sound
I have never known nylon bearings to squeak.
What is a Jig-A-Loo.
Could the nylon simply be drying out. What is the environment.
Ia dust from wear collecting.
Is there a repeated sterilization process that might be degrading the nylon.
Can the friction be controlled by a longer bolt with a spring between the head of the bolt and a big washer bearing on the nylon.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Make sure you have the Nylatrom with the highest loading of MoS2.
You may want to try using a dry lubricant like WS2 in lieu of the MoS2.  If you have very many to do there is a process where WS@ can be impregnated in to plastic.
You also may want to try Graphite.  In the same vain You could also consider Bron Nitride.
Ultra high molecular weight silicone masterbatch is available in nylon too. Perhaps that would help. Suppliers are Dow Corning Multibase and Wacker.
Chris DeArmitt PhD FRSC CChem
I too was thinking graphite, but if you are restricted to a food grade lubricant, graphite is not your answer.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
The UHMW silicone is food approved
Then again, there's astroglide...  or not.
Mike McCann
MMC Engineering
Motto:  KISS
