.DWG File Import Question...
I received an email from a vendor with a .dwg file attached (272 KB) that I requested. If I double click the attachment in the email and select "Open", Teamcenter Visulaization Mockup 2007 loads and the 2D data appears and looks exactly like what I requested.
So I go thru the same double click of the attachment in the email and this time select "Save", and I give it a name and it saves.
Now with NX4 open I import the .dwg file into an empty part file and only a few of the lines and some text import. I check to be sure all layers are selectable and everything is unblanked, but only a small portion of what was in the Teamcenter Visualization view has imported.
Can anyone help me solve this problem? There was a second and third attachment in that email and they imported correctly and their file sizes were similar.
Thanks in adavance,
Gary
Thanks in adavance,
Gary
RE: .DWG File Import Question...
its how i can see this through other soft
htt
The part is an Allen Bradley 140U-H3C3-C30A Circuit Breaker.
Any clues on what may be wrong?
