remote terminal voltage - transmission line
Hello Everyone,
We are developing some control applications in the local terminal of a 110 kV transmission line. The control requires to know the voltage in the remote terminal of the transmission line. We need to compute (or estimate) that remote terminal voltage, as we d like to avoid the implementation of a communication channel.
In the local terminal, all the key variables are available (voltaje, line current, active and reactive power, etc.). Assuming that the line positive sequence is available, could you please suggest a robust method to compute the voltage in the remote terminal?
Any advice is welcome! Thanks in advance.
RE: remote terminal voltage - transmission line
(2B)+(2B)' ?
could be implemented modeling the line as a single port with the ABCD constants determined considering line length and calibration during measurement and field test.
Thanks everybody! I agree that a valid answer to the problem is given by basic network equations, as pointed out above. Initially I expected something more complex, as an state observer for example. We will be running some tests.
Thanks again.
