Steam velocity in Pipe
I've been given the task of finding the velocity of steam in a pipe. But without the dryness fraction or specific volume given.
Given: Mass of water (565kg/s) (power station)
Pressure: 159.5
Temperature 565 degrees C
260mm inner bore of pipe. csa 0.056m^2)
Also the force of this steam on a 90degree swept bend with bend radius of 840mm twice the outer bore diameter
Pressure: 159.5
RE: Steam velocity in Pipe
Let's assume you are talking about 159.5 barg at 565 °C temperature. Then you're dealing with superheated steam (no mystery dryness is not specified). With those info and from steam tables you will find the superheated specific volume is 0.0218318 m^3/kg and then it should be easy (or at least easier).
Take a look here for second question
ht
Now i see there is a table for superheated steam..thats helped alot.
Thanks alot.
Rob
