flange facing
flange facing
what is selection criteria for flange facing? I heared for flange rating above 600, RTG is preferred, is that correct? any help will be valuable.
RE: flange facing
We routinely faces Class 2500 CS flanges and back side nut landing areas all time and normally no inspection is carried out other than possible thickness measurements.
On SS flanges of all classes and sizes we PT before and after machining. This required because we have problems with Chloride SSC. We normally don't reface Class 150 flanges. On large SS flanges where we suspect SCC and if there is radial flange crack we will check while machining.
RE: flange facing
thanks for your reply but I want to clear my question, for flange rating 1500 what is suitable flange facing, raised face (RF)or ring type joint (RTJ),and does selection based on service also ex.hydrogen service,H2S content.
RE: flange facing
The problem with RTJ Flanges is that they aren't many machines out there and usually the refacing is done by speciality contractors. I've seen several jobs where the people claimed the ability to reface RTJ's Flanges but in the end they failed miserably. We took the approach that it was the last resort to face a RTJ Flange. We have literally thousands of 3/4"-2" RTJ Flanges that get made up at least one and possibly 10 times a year, so we watch these closely as we don't machine on these we replace the flange, it's cheaper. There is a set of gauges for RTJ Flanges that will help you decide the condition of the seating surfaces.
One thing you can do is rent the tools to machine the Raised Face Flanges. This works out depending on the number of flanges and whether you want a contractor to come in.
On the Raised Face Flange, especially in our jacketed polymer piping system we routinely machine them. We have the in house capability of field machining up to 96" OD flanges. As I mentioned above we will back spot face the bolt hole, which is done more often than refacing.
RE: flange facing
I mention in my post about using PT while machining shown in this example. A little trick in doing this is to check and clear the and then apply a new coat watch whole machining. When you finish machining PT to clear the flange.
I'm a big fan of the Climaxx Machines and even though I don't have any experience with the new swing arm with a milling head. All of ours were the single bit swinging systems. Interrupted cut were tough whereas now the milling head want even know they are there.
http:/
