stresses from LIST result and PLOT result don't match.
Hi Everyone
I am modeling a Concrete wall with SOLID65 elements and a steel frame is connected to the wall with a steel plate that is fixed to the top of the wall the steel frame is modeled using SHELL181 elements.
I have three pressure loads applied as circular area pressure loads, two acting on the wall with the frame attached to it and the third area pressure is applied to the other wall.
My material properties are linear-elastic and i am running my analysis in one step.
1. After I run my analysis and PLOT the contour results for the 1st principal stresses, I see SMX and SMN in the top left part of the contour screen GUI. But when i go into the results tree and select the LIST nodal solution for 1st principal stress the maximum and minimum 1st principal stress at the bottom of the list does not match my SMX and SMN in the GUI this is the case for other stress results.
Why is that???
2. To apply the circular pressure load to the side of the volume I build a cylinder volume into the rectangular prism wall volume, then partition the two and then glue them together so they would interact when meshed. then I apply the pressure load to the cylinder circular area.
but because my wall is split into two sections and is no longer a rectangular prism because of the cylinder inside it which is glued I cannot do a hexahedral mapped mesh and i have to do a tetrahedral free mesh which is less accurate.
How can i apply this circular pressure to the side of my wall without chopping it into segments?
http://ansysx.blogspot.com/2011/03/plot-and-list-1st-principal-stresses-do.html
RE: stresses from LIST result and PLOT result don't match.
Try turning off PowerGraphics. That sometimes throws off results a smidge bit.
