Xrefed Objects NOT Visible in Plan View
Files "Test Xref.dwg" & "Test Insert.dwg" were respectively xrefed and inserted as block into file "Test Xref vs. Insert.dwg". As you can see all of xrefed objects are NOT visible in the plan view while inserted objects are visible. Anybody knows why?
iv
iv
RE: Xrefed Objects NOT Visible in Plan View
