Stainless bolts or screws used in aluminum structures
Can we use Stainless bolts or screws in aluminum structures?
will that cause corrosion due to two different metal in direct contact?
thanks.
thanks.
RE: Stainless bolts or screws used in aluminum structures
http://www.FerrellEngineering.com
Mike Halloran
Pembroke Pines, FL, USA
Most of the things I work on are aluminium with stainless steel screws. I am not aware of corrosion problems.
All of your aluminium should be anodized, chemical filmed or painted.
Interesting point, but I always wondered if there would be localised corrosion of the aluminum around the hole.
