SolidWorks Simulation 9 MATRIX_SINGULAR_OR_INDEFINITE
Hi guys,
I've attempted bumping an old thread as I imagine this problem occurs frequently but I could only find closed threads.
Early this year I ran a study to analyse the stresses within a quarter model of a cylinder head. It was an assembly drawing with five parts and the study ran fine.
I have since adapted the main body to be more complex and I can no longer run a study as this error occurs. It contains the same number of parts and I have checked that the loading and restraints are matching.
Any help would be much appreciated.
Thanks,Dan
Thanks,Dan
RE: SolidWorks Simulation 9 MATRIX_SINGULAR_OR_INDEFINITE
A matrix will not be positive definite if the model is under constrained or has some badly formed elements (that have essentially zero stiffness) or if the model has more than one correct solution (buckling). So check your boundary conditions and your mesh and whether or not there might be buckling.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
After searching through my model I noticed that I had made a mistake when applying the fixtures on some of the parts.
A very silly, simple mistake.
Dan
Another good habit is to check the reactions on the model after a run. They are in a .out file somewhere. If your boundary conditions aren't right you can sometimes pick up a problem there. The units are in MKS AFAIK.
TOP
CSWP, BSSE
