Resistance to Ferric Chloride
Anyone have thoughts on either a base metal or coating that would offer resistance to ferric chloride fumes at ambient temperature? This would be for a constant force type spring (i.e. clock spring).
RE: Resistance to Ferric Chloride
Look at Hastelloy C-22 or similar.
Metengr--I was afraid you would say that.
If my memory serves me well Titanium is good up to 50% and boiling in Ferric Chloride Solution.
I believe this ins in the old Timet Corrosion Tables if anyone has them.
Thanks for the responses. I am in a classic situation of having to fix a project that the client has already quoted (they quoted 301ss for the app). So, basically the client does not have a viable program at this point. Oh, well.
Fumes only?  Ambient temperature?  Could you not get away with a nonmetallic coating?  Spray applied PFA for instance?  Depends on how big the spring is.
moltenmetal--it may that a suitable coating exists, but given the potential liability of a ferric chloride spill (the spring is used on a transportation vehicle hatch closure)and the lack of time/resources for testing, the only safe route is to go with something bullet proof.
swall,
For bulletproof, I agree with metengr (Hastelloy C-22 or similar) and unclesyd (titanium).  A coating seems like a really big risk unless the entire process from manufacturing through assembly to end use is optimized.
Here is a link to the product bulletin for HASTELLOY® C-22® alloy:
http://www.haynesintl.com/pdf/h2019.pdf
Here is a link to the Timet corrosion info:
http://www.timet.com/pdfs/corrosion.pdf
Is this spring like the torsinol springs seen on a lot hatches?
if so when we had a process that used Ferric Chloride there we some components of 316 SS that would occasionally see what little vapor there is. I believe the 301 SS steel might work if it would have only brief exposure to the liquid and rinsed off after the exposure.
Yes, unclesyd--from what I have been told it is a hatch cover spring. Were I the manufacturer of this device, I might be inclined to proceed as you suggest, as I would have some control over the testing necessary to validate such as an approach. But as the supplier of a component spec'd by others of unknown technical competence, I put my company at risk by suppling something less than bullet proof.
If this a spring, and at spring hardness and stress, then a "C" alloy (22, 686, 59) or Elgiloy or MP35N are about the list.
Ti makes bad springs since they have to be over twice as large due to the low modulus.
Plymouth Tube
If this spring is external as they are normally are I can see exposed to is a little splash which would be washed off prior to shipping.  Our standard procedure on covers of this type is to fill, close, and rinse off where you have a waster drain. We got a fine years ago because there was white stuff reported around a cover on a tanker truck. This was recorded as a leak when in reality it was material that wasn't rinsed off and was reacting with CO2 in the air.
What is the container made of?
Could you post a picture of the hatch and cover?
edStainless,
Normally this is a very big spring probably weighing around 10-15 pounds so making it from any of C-22, Elgiloy, or MP35N would be extremely expensive $450 US ea. for a 1 1/2" by 3/4" dia. of .016 wire for use in a pump in Cupric Bromide service. The order was for 10 springs.
