Thermistor sensor on outside of pipe to test fluid temp
We are designing a temp sensor to test fluid temp of a coolant. Problem is the coolant cannot be easily drained to insert a probe in the coolant stream. The two options we have are to design a puncture or penetration probe to insert in the rubber hosing that transfers the fluid or to simply attach the probe to the outside of the hose and build a custom calibration for the sensor to read on the outside of the rubber hose.
I am kind of concerned as to the thermal reactivity of the outside of the rubber hose.
Just looking for some experience here to decide which direction we should go. Common sense says get into the coolant stream and keep things very accurate but that could prove problematic.
RE: Thermistor sensor on outside of pipe to test fluid temp
That's a very fancy technical sounding phrase.
What's it mean?
2) you'll need to measure the ambient temperature as well, as this too will affect the temperature of the pipe.
3) is this a one off installation, or will you be meauring many installations (ie many pipes, all the same part number) ? i'm thinking about the difference between measuring a single pipe or different pipes with the manufacturing variabliity to be considered.
4) plus/minus 1degF sounds awfully tight to me ...
You can proceed this way (assuming steady state).
Qout is the heat (per unit of length) due to convection from the outside of your rubber pipe to the ambient (neglect radiation as probably you are not working with high temperatures).
Qout = 2PI*rout*hout (Twout – Tamb)
Twout = pipe outer surface temperature (you can measure it)
Tamb = ambient temperature in the surrounding of the rubber pipe (you can measure it)
hout = convective heat transfer coefficient (assume it is 5 W/(m^2*K) for natural convection)
rout = outer pipe radius
Qcond is the heat (per unit of length) transmitted with conductive mechanism through the pipe wall
Qcond= 2PI*lambda*(Twin – Twout)/ln(rout/rin)
Twin = pipe inner surface temperature (unknown)
lambda = rubber thermal conductivity (you have to know this)
rin = inner pipe radius
Qin is the heat (per unit of length) due to convection from the inside of your rubber pipe to the fluid.
Qin = 2PI*rin*hin (Twin – Tf)
Twf = fluid temperature (unknown)
hin = convective heat transfer coefficient (it depends on your fluid, its flow regime and its temperature)
In steady state it must be
Qout = Qcond = Qin
From: Qcond = Qin you calculate Tf and then check back whether hin you've assumed converge or not.
It is a trial approach and it will give you an idea of the fluid temperature.
is the pipe lagged ? i'm guessing it is ... this might insulate a probe on the outside of the tube from the surrounding environment.
personally, i'd test the installation. if you can't test the pipe you're measuring (maybe it's installed and in process) then build a test piece, run with fluids of known temp.
In some discussion here, I am pretty concerned of the delta Ts we will see in the piping. The piping OD is subject to ambient outdoor temps which can fluctuate radically as well as the fluid temp that will also not remain constant.
In short, I am kind of thinking testing on the OD of a rubber pipe is a bad idea in this application. Just thinking out loud here.
You could modify ione's approach a bit to include a layer of insulation.
But you'd still need to know the hose thermal conductivity and still need to make assumptions about heat transfer coefficients at various surfaces.
You want this to be universal, but hoses are not universally of the same construction, and hence not the same conductivity.
With so many unknowns and assumptions built in you'll never hit your accuracy goal.
What is the pressure in the system? Is the rubber hose attached with hose clamps? It is sometimes possible to loosen a clamp and slide a bead-type thermocouple (lubricated with silicone sealant) between the metal and rubber to get to the coolant.
Engineering is the art of creating things you need, from things you can get.
