Creating Columns In Bom that Pull Info from the Drawing title Block
Does any one know how to create columns in the Bom that will pull information out of the title block. Drawing number, elect. Sounds repetitive but i need it for my application
RE: Creating Columns In Bom that Pull Info from the Drawing title Block
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
You can create new columns by right clicking on the BOM->insert column. You'll then be prompted as to what the column is for. Once you have it set up as you want, right click->Save As and save your new BOM template.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
I know you can then export because I do that with Open Office.
SW 2010 SP 4.0
