section view edges missing
Hello...
Using NX6. Taking sections thru my part, and several views have edges of the sectined part missing. the crosshatching is there, but the edges of the part are disappearing.
Is there a fix? Have I toggled something on/off?
ted kralovic
liverpool, ny
VisVSA, NX-6
RE: section view edges missing
Make sure the views are up to date, then try changing the view tolerance. Sometimes a smaller tolerance helps, sometimes a larger tolerance does the trick. Make sure the 'show background' option is toggled to what you want.
If this is an Assembly, also check to see if you have interfering parts.  If so, you may need to change you View 'Style' and set one of the alternative settings for handling the proper display of 'Interfering Solids'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
