Example Drawings for STC approval.
I'm trying to create engineering drawings for a structural nose cone assembly on an aircraft. All the parts are designed and I'm trying to represent the drawings to show how to fabricate and assemble these parts in the correct format. Is there anywhere on the web I can look at example fabrication drawings, particularly sheet metal to use as a guideline to how they need to look? Also I would like to know how installation drawings are represented. The ultimate goal is to take these drawings and use them for multiple aircrafts and satisfy the FAA guidelines.
RE: Example Drawings for STC approval.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I'm curious if for example; do you tolerance a flat pattern on a sheet metal part? And how do you show that formed and riveted on a installation?
there are probably many design manuals on-line, i'd expect that some part of DoD has there own as well. has your group produced drawings in the past ? but there are some guidelines ...
1) you need to put in all the information necessary to produce the structure you want,
2) you might consider that someone'll be inspecting the assembly to see if it conforms,
3) you might consider that someone'll be making the assembly ... you can make it easier for them if you build up your assembly to help them to put it together. most large OEMs have a planning department that does this, the difference between "as engineered" drawings and "as manufactured" drawings.
It's only on the installation drawings I'd think you might stray a little from the norm toward unique FAA requirements but I don't know for sure.
