Column reinforcement in bundles (Do they have to be of same sizes?)
Dear colleagues
Recently I was encountered with a design of large column section. To make it simple, bars could be grouped in bundles and the code that I'm using is BS, it allows for bundles of 2,3 and max of 4 bars. But it doesn't state that each bundle has to be made of same bar sizes.
So is it possible to have for example a bundle of 2Y16+1Y25 or 2Y20+1Y12 and so on??
It might cause confusion during fabrication but it can save some money (there are enough columns to provide sufficient material savings)
RE: Column reinforcement in bundles (Do they have to be of same sizes?)
The reason is, I believe, that the perimeter/cross sectional area ratios are different and can lead to quite different development of stress between the different diameters.
Use all the same size for simplicity. The extra capacity will not hurt either, assuming you can get adequate coverage.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
