Instance Feature
Instance Feature
A time ago John R. Baker has suggest to use the pattern face instead of the rectangular array or circular array because is the future.
The problem is that if I use the pattern face, the 'Array' command in assembly doesn't read in the array definition the 'From Instance feature'.
Suggestions ?
NX8 ?
Suggestions ?
NX8 ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Instance Feature
As for the next version of NX, Instance Feature IS being replaced with a new 'Pattern Feature' function, which WILL BE the 'future solution'. Note that we are also planning on replacing 'Array Component' with a new 'Pattern Component' function which will be based on the same common set of tools as is 'Pattern Feature' in NX 8.0 and as was the 'Pattern Curve' capability introduced in the NX 7.5 Sketcher.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
so at the moment I can't use pattern face in 'Array Component'.
I understand well, NX8 will not have 'Pattern Component', but only 'Pattern Feature' ?
Thank you...
Are you saying that if you use 'pattern face' in a part file that you cannot then use that part as the basis for a component array in an assembly? What is the problem you are having, exactly?
Example:
If I use rectangular array in the part (hole), I can use instance feature in the 'Array Component'.
Whit pattern face no.
I like pattern face, it's more powerful and parametric.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
