Elctrical Oven remote control with PC
We have 4 electrical oven in our plant
Each oven has it´s own temperature controler. We want to control and monitor the 4 ovens using one remote PC (20 meters from the ovens)
This are some of the functions that we need to do with the PC
manual individual start/stop of each oven
actual temperature display
set point modification
scheduled start
indication of finished process
Can anyone tell me what type of hardware and sofware is required for this project?
scheduled start
RE: Elctrical Oven remote control with PC
>> requires some sort of switch or interface to the switch on the oven
>> requires a sensor; is there one existing?
>> how is it done now?
scheduled start
>> only relevant to the PC
>> How is that done now?
Without some more information about the ovens themselves and how the processes are controlled and monitored, it's hard to say. At the minimum, if these ovens are "dumb", you'll need to do significant modifications to the oven controls and displays by adding switches and sensors. If these are "smart" ovens, then you may only need to connect to their command/status interfaces.
TTFN
Chinese prisoner wins Nobel Peace Prize
The ovens are very simple
Heating source: Wire resistances
Control mecanism: Load Contactor. The contactor feeds the resistances and is open or closed by a temperature controler. The temperature input to the controler is done with a J type termocuple
2 of the ovens have a fans for air recirculation. The fans are switch On and Off manually at the beginnig and at the end of the process
I think the oven are "dumb"
TTFN
They have scads of controls and systems to do exactly that. Peruse around there.
You will need a new temp controller for each oven that has communication ability. There will be many possibilities. Pick one that allows you to daisy chain them all to a PC.
The software will then present you with a screen that allows you to set any setting on each of the controllers. It usually allows you to set alarms and ramp and soak stuff too.
Most allow you to log the temperatures. This lets you compare what happens in the oven to your product's quality. This can be very helpful when you find your product suddenly has some sort of baking related issue.
Keith Cress
If all that control terminology is Greek to all the people in your plant, then consider finding a local distributor who carries temp controls and software and who does 'integration'. Hire them to do the installation and start-up to get the software talknig to the controllers.
The telephone tech support for the component stuff generally assumes you're fluent in the terms the trade works in.
