Un-folded view representation
How to show a Revolved or Un-folded view in drawing. Please see the attachment for the details.
Thanks and regards
Muzamil
Thanks and regards
Muzamil
RE: Un-folded view representation
Once it is made in the drawing you will need to choose the section you made, then choose the "Full(Unfold}" option. You can display section lines like usual on the parent view.
The Unfolded display can be obtained by choosing Full(Aligned) from Sectioned Area drop down then choosing the unfold axis.
Michael
@trajpar
Just kidding,
AFuni
Well maybe you can answer me this?
After getting the FULL(Aligned) view gets created now it's locked as such. This is ProE you have always been able to switch a view type after creation and modify it. I assume if you create an aligned view you'd wan't to keep it as such but shouldn't that decision be mine. I think it's in the ProE constitution.
This may be a bug the + - arrows go away and you can't right click and choose remove.
was using WF2 for this one but will check 5 to make sure it has this problem.
Michael
@trajpar
CreO, different name same functionality.
Michael
