EPDM to EPDM Bonding
I need to make a mould structure for a artifical stone manufacturing process using a sheet of EPDM and bond another piece of EPDM on the edge of the sheet so that it forms a tray like structure. This tray will need to withstand cyclic heating and cooling 5 deg to 120 deg.
Advise me on the strongest possible method to bond EPDM to EPDM
RE: EPDM to EPDM Bonding
http://www.reltekllc.com/rubber-adhesives.htm
EPDM does bond nicely using cyanoacrylate adhesive, but the joint is brittle and won't take much peel/shear before failing. If the area of the joint is supported (like an o-ring in a groove) it can work.
http:/
That being said, aside from testing, I found 3M to be a great resource. Even the rubber guys I was working with worked with 3M to get the right bond.
A shot in the dark... what about just CA? Depending on how long the heat cycling is you might be able to get away with it.
Chris Loughnane - Product Design
http://www.pdnotebook.com
http://www.twitter.com/_chrisloughnane
