How to calculate equivalent cross-sectional area of thread contact?
On #3-56 threads (small threads) how could you calculate the equivalent cross sectional area that would be made by the metal on metal contact in the threads for a given length of engagement?
If anyone can explain or just point me to a website I would appreciate it.
Thanks a lot.
Thanks a lot.
RE: How to calculate equivalent cross-sectional area of thread contact?
htt
http:
http://www.hexagon.de/dose/form02e.pdf
http://www.hexagon.de/dose/dose-1e.pdf
Also, verify that the calculated pull out force will be accurate for your actual case: if both metals (male and female) are not the same yield strength, the weaker will yield first.
Nbr 3? That's an unusual size.
