Huth Eqn.
Huth Eqn.
Huth Eqn.
Can the Huth bolt equation be used for double shear when all three plates are different (i.e. top and bottom plates aren't identical)?
RE: Huth Eqn.
FWIW ...
sure, i'd model as two equal plates, the average thickness
or you could model each shear face separately, ie 1/2 the middle plate with either outer plate and add the two single shear stiffnesses together ... not sure if huth has a term to account for the offset loading of a single shear interface.
RE: Huth Eqn.
Thanks rb1957 for replying,  this is very helpful.
I do have one question though, would you pretty much have to go with your second suggestion (i.e. making 2 single shear calcs and adding them), since the sandwich plates are different E's?  Or could you average the E's?
Thanks again,
RE: Huth Eqn.
almost forgot to mention, the core and one of the sandwich plates are laminate, the remaining sandwich plate is metal.
RE: Huth Eqn.
sorry brian but this is unfortunately a typical eng-tips post ... the story evolves with each post, and much time is wasted.
so it sounds like you have a sandwich panel (metal faces, honeycomb core?) joining two other plates (both metal, or one is composite ?)
if the honeycomb core fastener doesn't have a bushing then i'd consider the two faces as separate bearing surfaces.  if it does have a bushing you Might consider it as one thick plate.
different Es should be accounted for in Huth, directly ... it's a while since i looked over the equation, but i remember Es all over the place.
if one "plate" is composite ("laminate"?) i'd be careful ... huth was developed from testing metal joints, and composites have a nasty way of not acting like metal.
apologies for the opening rant ...
