TeamCenter - Deleting A Workflow Process
I am looking to remove or delete the workflow process started with a part. It is the symbol in TeamCenter that looks like a baseball diamond. How do I go about doing it? Someone showed me how, but it has been a while.
RE: TeamCenter - Deleting A Workflow Process
select the item revision and click on referencer tab on the Right side. toggle the drop down of "Where" to Referenced>> click on the Item revision you see in the white space below >> you will see all the workflows attached to the item revision>> select the correct one and delete it..
You can check on the properties of the workflow to confirm you are deleting the correct workflow.
select the Job for the appropriate Task and delete the Job..
Hope this helps..
