GD&T Feature Control Frame Formatting
I think this is more a SW question than a GD&T question.
I am trying to make a feature control frame similar to Fig 6-15 (p.106) in ASME Y14.5-2009, perpendicularity of an axis with zero tolerance at MMC with a max tolerance specified. I can't seem to get the MMC symbol between my zero tolerance and my max tol in a single feature frame. Any work arounds?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: GD&T Feature Control Frame Formatting
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
Don't cut and paste. Just type the tags directly into the edit field where you enter the number values. I just tried this and it works well.
Matt Lorono, CSWP
