"Laminate" a Sheet to a Plate?
Hi All,
I have an electrical application where I want to weld a common busbar to several contacts.  I need the contacts to be flexible for tolerance/vibration considerations, but the main body should be thick busbar for high current.
My perfect solution would be to "laminate" a thin sheet of something with good electrical and welding properties (nickel, aluminum) to an aluminum plate that would serve as the busbar.  This way I get the benefit of both shapes, and better conductivity than if I welded separate tabs on for each contact.
Does this type of process exist?  What materials work?  Thanks for any help!
Cheers,
Rob
RE: "Laminate" a Sheet to a Plate?
Explosion bonding perhaps.
Don't know if it like having bits hanging over though.
Explosion bonding is a kind of cladding. Many electrical parts are made that way.
