Would Heating an Aluminum Baseball Bat Make it hit Better
Question came up this past weekend during a college baseball game. Would like to get some expert opinions on the subject.
A bat's deflection at impact acts like "trampoline" for the ball so heating up the bat could possibly make it deflect more, possibly giving it more spring. On the other hand , heat it up too much and it could dampen the impact. I would think heating it up could possibly improve the hitting distance of the bat.
What do you think?
What do you think?
RE: Would Heating an Aluminum Baseball Bat Make it hit Better
Reason being, heating the material will lower the modulus of elasticity and there by reduce the overal structural stiffness of the bat. Lower bat stiffness would imply lower impact forces.
Interesting question though.
More interesting....who is going to hold the 500 deg F bat.
Announcer: "Next up number 9 in his thermal protective suit..."
Stephen Seymour, PE
Seymour Engineering & Consulting Group
www.seymourecg.com
TTFN
Chinese prisoner wins Nobel Peace Prize
From what I've read, the deflection of the bat "trampoline" effect, allows the ball to retain more energy. If this is the case then a bat heated could possibly have an effect on the amount of deflection as Seymore stated.
there are obviously a couple of competing mechanisms ... would the bat absorb more strain energy if it was slightly softer ? would a slightly softer bat return this energy more efficiently to the ball ??
Research and development for the alloy determine the best hardness/strength and aging conditions. Heating up too much will change the aging.
Might try that?? Not sure why it might possibly work?? But it did work on golf balls!! Supposedly??
Warming the bat beyond 90 deg F is impractical and probably results in no added gain, especially if the ball is between 70-90 deg F.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I am not familiar with the "rolling" of composite bats, but I could see how that would be far more dramatic than simply heating a bat by 20 or 30 deg F.
As far as a hot day versus a cold day, I suspect the change in air density would have a lot more to with that than absolute bat temperature.
Brian
www.espcomposites.com
Testing Procedure Explained (BESR):
http
What really matters here, the modulus of elasticity, or the aluminium's ability to recover the stored strain energy?
Elastic modulus is important in impact analysis when you are trying to reduce the deceleration to avoid damage to equipment and people. All a baseball bat has to do is not destroy the ball.
It may be important that you match the elasticity of the ball and the bat. I am trying to visualize this. There ought to be some sort of shock wave in the ball.
http://paws.kettering.edu/~drussell/bats.html
TTFN
John R. Baker, P.E.
Industry Sector
Cypress, CA
http://www.rawlingsgear.com/news/article/193
htt
ball_Bat_3DXAB/content_66799701636
College baseball has recently banned composite bats due to players "rolling" the bats breaking the fiber layers in the bat and giving the bat an increased hitting distance due to increased "trampoline" effect. Now, aluminum bats are all that is allowed. And these aluminum bats have to be BESR Test Approved. (http
Looking for advantages in hitting ability, players are heating their bats before they hit. Question is, if the batter heats up his bat before he hits, can it possibly help?
Dik
What was happening with composite bats was a completely different phenomenon. Ball players are pretty superstitious so I suspect placebo would have more affect than actually heating the bat.
Brian
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
Tobalcane
Actually a stiffer bat will cause the ball to lose more energy due to internal friction whereas an aluminum bat momentarily stores the energy and returns it to the ball at impact.
www.he
www.sgma.com/img/home/russell-tuned-bat.ppt
But what I don't understand is there is a reference that demonstrates the properties do not significantly change over reasonable temperatures. I would argue that manufacturing tolerances, processing, etc. would be a more significant affect.
What else can be reasonably said about it?
Brian
Tobalcane
fibers" you would have to talking about Fiberglass or Composite Bats
http://worthsports.com/bat-technology
TTFN
That's the point. The BESR testing does not specify a testing temperature as far as I can tell. Therefore a BESR approved bat could be tested at room temperature then heated to say 90 degrees F before you get up to bat by means of some type of heater and the bat could obtain properties that would surpass allowed BESR limits.
This is what happened during a college game last weekend. The batter got up to bat, hit then the catcher noticed the bat was "hot" to the touch so the bat was protested.
I would think that a bat manufacturer could design a bat to pass the BESR yet have better hitting properties (beyond BESR limits) when heated to say 90 degrees F. Nothing in the rules that say you can't heat a bat and no good way to enforce it.
Seems plausible to me.
And this would not be that difficult to prove. A $20k thermal camera could be used to demonstrate that a team, or a player, is using a "hot" bat, and the measured tempeature from the thermal camera would then be used in the BESR testing.
TTFN
Great reply IRstuff. Thermal camera is a great idea that I did not even think of. As for the BESR testing, I'm sure this will be addressed before next season at the BESR testing facility. However, don't think they can test them during a game. Great post though. Very helpful.
Mythbusters is good idea too though.
Maybe that I need to be in the bat warmer business like the used for race cars.
For every 200F delta change there is about a 5% change in elastic modulus. There is a reliable source for this in Mil-Hdbk-5 or MMPDS. For the scenario indicated, there may have been about a 20F delta, and perhaps a 0.5% change in modulus.
This may lead to some very minor distance change, say 2-3 ft, but this would hardly be measurable, statistically relevant, or something a governing regulation would care about. Especially for college baseball...at least that would be my guess.
Is there any other real evidence, engineering source/property, etc. to indicate otherwise? There is nothing else provided in this thread. There really does not seem anything more to it than this. Is there a counter argument to what I have said?
Brian
There's a big difference between testing for product compliance vs. testing for tampering. In the latter case, the investigator (say, me) would use the imaged thermal data to determine the temperature of the bat and test the BESR at that temperature. Any other temperature would be completely irrelevant to the investigation of tampering.
TTFN
TTFN
Swing batter batter batter swing.
I understand that that small of a change in the temperature of standard aluminum alloy will change the modulus of elasticity that small of an amount. However, how do you get from that to only a 2-3ft change in distance? What parameters are you using in your model? Bat speed? Ball speed? Ball coefficient of restitution? Bat length? Double wall or single wall bat? Thickness of aluminum? Flexibility in the handle of the bat? Etc...? Surely a bat could be physically designed that could take advantage of the small changes in the modulus of elasticity with temperature to maximize the transference from the bat back to the ball.
Also, surely there are numerous elements or types of alloys that have different properties which heating from 70F to 90 or 120F would maximize the delta in modulus resulting in maximized "trampoline" effect. Or if you prefer the maximum transference of kinetic energy back to the ball.
Looking for possibilities not limitations.
Very true.
International cricket broadcasts now include "hot spot" cameras - infra red video cameras that show clearly where the ball has struck the bat or batter.
http://www.itsonlycricket.com/entry/437/
Engineering is the art of creating things you need, from things you can get.
"Looking for possibilities not limitations."
But there could be problem with this thinking. Are you sure you are being objective, and not selectively considering what you want? Are you the one who was complaining about the bat? haha.
I made the assumption that elastic modulus is the dominant property when it comes to the trampoline effect. That would seem reasonable. I would encourage you to investigate the change in modulus with varying alloys. It is relatively insensitive to alloy, heat treatment, etc. (unlike material strength).
If you determine the elastic modulus changes by only about 0.5%, then it is all relative from there. All of those other variables are relatively meaningless since even if it is not a direct relationship, the effect should be nothing more than minor. If a homerun is about 400ft, then a 0.5% difference is 2 ft. Accounting for some variability in the relationship behavior(i.e. the variables you stated), then maybe 3-4ft.
Now, if there was any other information as to the fundamental physical property that I have overlooked (i.e. that it is not based on elastic modulus), that might be another thing. But so far, there has been no mention of what that might be.
The point is, unless you have a significant change in the fundamental physical property that dictates distance, I don't see how you can have a real world difference.
Brian
That assumption is only true if the ball is infinitely stiff. Energy is lost when there is ball compression.
I'm surprised that the exact relation between the stiffness of the bat and ball has not been explored. To me that ratio seems to determine the maximum "trampoline effect" physically possible.
In other words minimizing the dampening effect of material deformation seems to be the name of the game.
Check out this ppt presentation by Dr. Russell, the expert in this field.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
Of course, there's a limit. It wouldn't do you much good to go out there swinging a noodle.
When it comes to heating up the bat? I wouldn't want to be holding it if you made it hot enough to make a significant difference in the stiffness. You'd probably have better luck rolling the aluminum bat to a slightly smaller diameter just above the handle.
Obviously you have not read any of the previous posts or links to explanatory material. The "trampoline effect" is a little more complicated than an impulse. It is not the same thing. This is a real world situation with an inelastic collision. Kinetic energy is lost in internal friction from the compression of the ball and bat. The internal friction of the ball compression is minimized by the bats deflection and more of this energy is returned to the ball than that of a rigid bat.
Check out Dr. Russell's (Phd in Applied Physics) work in this area: http://paws.kettering.edu/~drussell/bats.html
for reference there is a 8 % change in air density over 40 degrees
(~32 feet on a 400 foot hit is quite a large change)
I spent hours..maybe days in the batting cage trying to get something special out of that bat. Other guys tried it and they hit ok but not for the price of the thing. When I retired from all sports (doc said I was worn out) I donated it to an arch rival team. Nothing like giving your junk to the other guy. haha
As for heating bats..yeah it was tried, there are a number of heat pads available but by the time your grab your 'hot bat' and get to the plate it's cooled to nearly ambient. By the time you get to a 3-2 count The hottest part of the bat is where your hands are so what good does that do?? We tried it a number of times in batting practice but if there was a difference we sure didn't notice it. Even against a pitching machine there wasn't any measurable distance noted. How hot can the bat be before you are uncomfortable with it?? 40 deg over ambient I think would be pretty hot.
99 Dodge CTD dually.
TTFN
Anecdotal evidence, supported by engineering data, suggests no realistic effect.
Brian
The author was commissioned to do the book by MLB.
http:/
Sunday afternoons, sunny days, hot-dogs, Cracker Jacks, seventh inning stretch, and large doses of androstenedione...
tg
PS: I did NOT use steroids to write this post.
Around 2003-2004ish Easton introduced a two-piece bat called the stealth. It was an instant hit (no pun intended). The handle was a seperate piece from the actual barrel. In theory, as you swung the bat, the two pieces together would create a slapping effect on the ball. I would compare this to the way a golf club wraps with swung with a lot of force. Consequently, the lfie of the bat was short. Soon after, they produced two types of the stealth, a more flexible version (for hitting longer distances) and a stiffer version (for longer life). Then, they produced a composite version of the same bat. I never cared for it but some swore by it.
I agree with ESPcomposites, I believe the heated Al would not make and difference and baseball players are known to be superstitous. However, I always felt that the two piece and composites bats never performed as well in 50 degree weahter as opposed to 80-90. We always played our first game around the 25 of Feb, very cold. Not many homeruns were hit until spring break. But one may argue that the beginning season is when players are getting back in the swing of things and will not hit as well.
Anyways, there is my two cents.
I think someone should work more on extra special glasses to allow you to see the ball the way Ted Williams could. He always credited his hitting ability to his incredible eyesight.
I think it was his sight processing speed that gave Ted his ability. It was said that he could read the trademark on the ball of a fast ball pitch while spinning and whirling towards the plate.
I agree that it probably isn't the properties of the aluminum though. The same "dead" feel to a bat also happens when a bat gets slightly dented. When that happens the bat is consigned to the practice field.
Could the increase in air pressure within the bat at different temperatures affect the stiffness enough to make this difference?
Brian
SNORGY.
Dik
