Internal angle of friction for crushed limestone
I read with interest a thread now closed that dates back to July 2010 on a similar subject. I am trying to evaluate the internal angle of friction of crushed limestone as a backfill material (max. particle size of 25mm). I had 30cm x 30cm (1ft x 1ft) direct shear box tests on the material. The angle of internal friction came out pretty high (65 to 80 degrees). We are testing at very low normal stress ( 10 to 50kPa). Due to the Mohr envelope curvature, it is not unexpected to have high angles at such low pressures, but these values seem quite high. Anyone has some experience/feedback? Thanks.
RE: Internal angle of friction for crushed limestone
Was there dilation? You may be measuring the dilation angle and friction angle.
I had to think about it while running some basic shear box tests the other day.
I've used it on various waste products also, with success.
The suggestion then, if results are critical, use more normal force.
