shadow shots
3
shadow shots
shadow shots
Can someone explain what shadow shots are and where they would be useful?
RE: shadow shots
If you are talking about a paralax shot where a defect is shot from two positions on the same shot.  It is used for depth of defect location.
RE: shadow shots
Concur with ledon.  However, if available, UT-shearwave is faster - thus cheaper - and more accurate as to the upper limit and the max depth of the flaw.
RE: shadow shots
A parralax shot is used to locate the depth of a defect in thicker materials.  You would shoot the RT at 1/2 time, reposition the source and complete the shot.  This produces two shadows at different positions on the film.  A little trigonometry and you have a depth location.
This is rarely used anymore for the reasons Duwe6 mentioned.
RE: shadow shots
"shadow Shots" usually refers to profile radiography which is usefull in piping up to 10" NPS for corrosion /damage assessment and can be done without removing insulation.
