Vessel Stored Energy Limits
6
Looking for a good industry standard reference for calculating stored energy in pressure systems and determining safe working distances?
RE: Vessel Stored Energy Limits
Me too.  Standards for Pneumatic testing don't exist.  What do our fellow engineers consider adequate safety zones, please?
The next county should be safe. Anecdotally, I have seen a few tons of 2" thick head (about 8ft dia) break loose, tearing off 12" pipe connections, go 100' up and land 300' away; due to 300 psi nitrogen. You add explosions or detonations and it seems pretty difficult to predict a "safe" zone.
I found ASME PCC-2-2008 Repair of Pressure Equipment & Piping. In the mandatory appendix is a method for calculating stored energy & safe distance (pg. 197-198). This was sufficient for what I was doing, but I have heard there is a NASA document that addresses this issue, if any one has that reference, please share. Thanks for the comments :)
Consult the February 2011 Issue of Chemical Engineering Magazine.
@ione: Thanks, I like to use NASA specs when working with NASA, this was a great help :)
I wrote something that I think is pretty much exactly what you are looking for.  It is based on the NASA-Glenn approach, which used to be in the public domain via their website, but is tough to find now.  I even wrote a little spreadsheet that calculates the stored energy levels and safe working distances for you.  If you want, I will make it generic and upload it.
SNORGY.
snorgy, by all means.  There should be a number of us that would use this spreadsheet.  I will, for sure.
Do a stored energy calculation by:
E = (PV / k-1) x (1-(Patm / P)k-1/k, where:
E = Energy in Joules
P = Absolute pressure in Pascals
V = Test volume in M3
Patm = Atmospheric pressure in Pascals
k = Ratio of specific heat of air
Then convert to TNT:
TNTlb = E x 4.8 x 10-7
The safe distance can then be calculated by:  SD = 15 (TNTlb).5
I use this for calculating safe working distance for all pnuematic tests.  There are similar for hydrotests, but the stored energy is obviously a whole lot less.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
Ooopps, should have been:
E = (PV / k-1) x (1-(Patm / P)^k-1/k,
and
SD = 15 (TNTlb)^.5
Greg,
I'm assuming that TNTlb is equivalent weight in pounds.
What units for SD ?
Cheers
Dunno about you, but I'd pick miles? :)
Correct on the TNTlb.  SD = Safe Distance = meters, sorry should have specified.
If I take the liberty of pirating Greg Lamberson's posted equations, I obtain the revisions per the attached link.  The agreement in results is pretty good based on the cases I ran.  The differences are probably because the curve fit correlation that I used for the NASA-Glenn curve probably could be improved a bit.
Greg Lamberson's equations may be better than mine.
SNORGY.
