pressure drop due to obstruction in pipe
LS,
If a small cylinder is placed in a pipe, what will be the pressure drop.
The force acting on the cylinder will be:
F=Cw*A*0,5*rho*v^2
Flows are turbulent (Re>10000).
Should I use an energy approach?
Thanks DYV
F=Cw*A*0,5*rho*v^2
Thanks DYV
RE: pressure drop due to obstruction in pipe
Good luck,
Latexman
this has been discussed before:
thread378-236832: Losses through long annulus.
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
The flow is normal to the surface of the cylinder. The cylinder is fixed to the piping wall.
Piping is DN50, and the cylinder has a diameter of 20 mm and a length of 35 mm.
On the internet I found a picture of how the flow is around the cylinder in this existing situation.
Flow will be approx. 18 m3/h (is approx. 2,5 m/s) and the fluid is light viscous (estimated at 10 mPas), which makes flow turbulent.
Pressure drop is very low, but it needs to be quantified.
DYV
Best regards
Morten
