Mill Tolerance on Plate
The mill tolerances on pipe are readily available but there appears to be no reference to mill tolerances on plate. What should be taken as a tolerance on plate? Also, should it be a finite figure or a percentage as per pipe?
RE: Mill Tolerance on Plate
Mike
