Has anyone made a Macro to do this....?
I am working with design tables for fairly large parts.  150-250 features.....
The DT approach we are using utilizes a lot of varying supression state combinations.  When you create a DT for part with this many features..SW often jumbles the order of the features...leaves some out, etc.  Getting them straight is a nightmare...especially with the goofy 90 degree text rotation....
I set up the feature tree using folders for organization. It would be awesome if there were a simple way to export the feature tree name data to a text file...in the same order as they appear on the tree.  This would save tons of time, and reduce errors a lot.
Ideally, the out text file would look like this....
Folder 1
Feature A:  Revolve
Feature B:  Cut-Extrude
Feature C:  Surface-Extrude
Feature D:  Split Line
Feature E:  Ruled Surface
Feature F:  Surface Extend
Feature G:  Surface Cut
Folder 2
Feature H:  Boss-Extrude
Feature I:  Cut-Extrude
Feature J:  Surface-Extrude
Feature K:  Split Line
Folder 1, Folder 2, Feature A, etc...are names that I give features.  This is the naming convention I used to keep info straight on huge Design tables.
Basically...just go down the feature tree...and output the name list.  I dont need to go deep into absorbed features....basically just the first level (if you consider a folder 1st level...then in that case...2nd level...)
RE: Has anyone made a Macro to do this....?
The features are being re-arranged or left out in/from the Feature Manager, or the DT?
Does the order of features in the DT match the order required in the FM?
Yes.  Some small sections are in order...but then the rest is all jumbled up.  When you have 100 features...this can get to be a real pain...
Are you able to post a sample part for review and testing?
CBL,
Can't share the model.  Proprietary.
Thanks for the offer, though.
-Brant
Can you not create a dummy example or drastically change (add and remove features) a proprietary one beyond recognition?
CBL,
The issue is that it has so many features....  Simple models do not behave this way.  This is a master model that could drive hundreds of future models....so it is very complex.  I just cant see re-creating this...
I guess I will just learn Macros.  Thanks for offering to help.
Till a macro is created, you could take a series of screenshots to capture the FM tree.
