Expansion joint
Expansion joint
hi all,
how long u think should be between Exapnsion joints in R.C Structures ? i have a building that is 50m long, do i have to make an Expasion joint for it ?? if yes, can i just increase the stresses instead of making Expansion joint ?
Pea$e
Pea$e
RE: Expansion joint
Vertical expansion joints also help foundation settlements over long distances.
Cheers
RE: Expansion joint
You can consider additional stresses in the concrete but most likely more cracking will occur as the joint distance is increased. Also wall finishes both exterior and interior may become distressed as the joint lengths increase.
RE: Expansion joint
i know my question was not spicefic, so to make it clear its a Villa 3 floors hight and about 50m X 10m, i and its in Egypt, cairo.
in that chart u r talking about, whats the maximum Length in my condition, consider the worest case or near the worest.
** Mr boo1, thx for replying, but i asked some fellows here and some say 40m, others say 100m !!i dont know about the 30m !!! i'm very confused now !!
Thx for concern to all,
Pea$E
RE: Expansion joint
mfrad's posting refers to other possible consequences. I suggest you refer to the documents which mfrad kindly listed for you.
Good luck.
RE: Expansion joint
RE: Expansion joint
Pea$e
RE: Expansion joint
