Steel 20MnCr5E
Steel 20MnCr5E
Steel 20MnCr5E
I've come across a reference to the above steel.
Can anyone tell me what is the difference between 20MnCr5E and the 'ordinary' 20MnCr5 I am familiar with??
TIA
Peter
RE: Steel 20MnCr5E
I'm not 100% sure about this, but I  think that  they differ slightly in impurities or alloying elements i.e tighter chemical limits or inclusion rating.
Mark
RE: Steel 20MnCr5E
The S indicates a machine grade, high sulphur.  There are no equivalents to the DIN specification
  C;; Mn; Si; Cr; Mo; S; P;
20MnCr5    0.17-0.22; 1.10-1.40; 0.15-0.40; 1.00-1.30; 0.03; 0.03
20MnCrS5  0.17-0.22; 1.10-1.40; 0.15-0.40; 1.00-1.30; 0.20-0.03; 0.03
RE: Steel 20MnCr5E
Peter,
The E is indicating that the material/part has been case hardened.  E and V are informally placed at the end of a steel designation to indicate the following:
E = Einsatzgehärtet = Case Hardened
V = Vergütet = Quenched and Tempered
I use the term informally because I have never seen this explicitly stated in a DIN standard, although it is somewhat commonly used in German-speaking countries.
RE: Steel 20MnCr5E
PeterCharles,
Sorry about that and I thank TVP for setting me straight.
RE: Steel 20MnCr5E
Thank TVP
Peter
