Required thrust lengths overlapping
I'm looking at the situation described in the attached, where valve A and valve B are both closed. Pressure beyond each valve is zero. Treating each end of the pipe as a dead-end, the required thrust restraint lengths overlap. However, all forces oppose each other. So if I restrain the entire length of pipe, all situations should be covered -
both Valve A and B closed,
Valve A only closed,
Valve B only Closed.
This is probably a stupid question, just want to confirm...
RE: Required thrust lengths overlapping
