Bend radius option
Bend radius option
I imported a Parasolid file.
I'm remodeling the part as exercise.
I'm trying to create fillet, but I'm not able.
I attach an image and the Parasolid file.
Which option I've to set to obtain fillets marked with 'OK' in the image ?
Which option I've to set to obtain a better fillet marked with 'Frown' in the image ?
The 'frown' result is not good, I would like a result where the two fillets die together.
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Bend radius option
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
sorry fore the delay.
I open your part, but it's not what I want.
Please see the attached image.
Thank you...
What you need to do is when you create the blend (or when you edit an existing blend) is to open the section of the Edge Blend dialog labeled 'Overflow Resolutions' and the section of 'Allowed Overflow Resolutions' toggled OFF the 'Roll on Edges (Smooth or Sharp)' option. If while the dialog is open, you press the 'F1' key the Help page which comes up will clearly show some examples, including one like yours, for how the various 'Overflow' options work.
John R. Baker, P.E.
Industry Sector
Cypress, CA
