Concrete on a slope
Concrete on a slope
Hi Guys
I have in the past seen concrete being pired on slopes, generally not an issue, just reduce the slump. I have a case where the slope is 2:1, i.e. 2m horiz/1m vertical. Could this be problematic and what tips could you offer for pouring on a slope.
In this case the slab is 15m long on the slope from top to bottom.
RE: Concrete on a slope
I have seen sometimes horizontal wood formwork implements are placed at what will be the upper surface at regular intervals (akin to raisers in stairs). This way when dumping the concrete some kind of extruding to thickness device is in place.
