NDE & Leak Test requirement for Hot Tapping
Dear All
To satisfy the examination requirements in B31.3, are NDE & Leak Test still necessary for Hot Tapping?
RE: NDE & Leak Test requirement for Hot Tapping
NDE yes, leak test no.
Even if leak testing is not required, you will want to do so...
How can you avoid it?
Not performing Leak test for hot tapping works is an industrial practice. Or there is section of a code/standrad that allows it?
Please advise. Thank you
Repeat.  How can you avoid it.  That's not a question.
Let your acquaintances be many, but your advisors one in a thousand'  ...  Book of Ecclesiasticus
How can you avoid it? Close your eyes!
Most would consider visual examination after the work is complete a "leak test."
B31.3 defines them as two separate things.
