Turbo Shaft Play Tolerance?
Does anyone know of a tolerance for radial and axial shaft play in modern turbos? Is axial tolerance zero? Can oil starvation cause shaft play?
I'm having difficulty finding anything but anecdotal information on this subject...
RE: Turbo Shaft Play Tolerance?
The above is pretty close to what I have heard as general guidelines. It does depend on the turbo, bearings etc. If you want to get more accurate than that I would try and contact the manufacturer.
I'd still like to hear anyone's comments on oil starvation and whether or not it can cause shaft play!
Bearing wear causes an increase in axial play.
Oil starvation is one way to accelerate bearing wear.
There is always some play otherwise no oil could flow and the shaft would seize.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Depends on the size of the turbo, the size of the bearings and shaft, and type of bearings (full floating hydrodynamic or rolling element).
A turbo for a (relatively) large CAT 3612 may have greater axial and radial play specs that a turbo for an 800cc smart car diesel.
For typical hydrodynamic journal and thrust bearing systems, and assuming that you are thinking typical pass car engine size, I would guess 0.001 to 0.003 axial play is OK (units are inches), and 0.001 to 0.004 radial play is OK. True radial play is difficult to measure without the correct probe. Accurate radial play should be measured as shaft excursion between the bearings when manually displacing both the compressor and turbine ends of the rotating group in the same direction.
Dick
As Dick says, the type and size of turbo will change things greatly.
Anecdotal evidence is all you are likely to get on an internet Forum.
Best to contact the manufacturer of the specific turbo for some hard numbers.
I'd say on a sleeve bearing turbo, oil starvation for any length of time at all would likely cause catastrophic bearing failure.
http://im
ww
htt
Agree it can't be zero - the oil film has to fit somewhere. It is possible to design a thrust bearing to maintain constant clearance under varying temperatures.
Engineering is the art of creating things you need, from things you can get.
Those don't have a single dedicated thrust bearing, but use the angular contact ball races at each end of the housing to locate the shaft.
Shaft expansion will tend to close up any end float, as the shaft usually runs hotter than the housing.
Sleeve bearing turbos are a whole different ball game.
I recall many years ago a case of incorrect axial preload on a ball bearing center section re-designed by a mutual acquaintance of ours (RH). It was for the Nissan '90 GTP race car.
The spool had excessive axial play. Every time the driver shifted or got off the throttle, the change in pressure force between the compressor and turbine would cause the spool to momentarily shift axially and upset the piston ring seal. A small amount of oil would leak into the turbine housing and create a big puff of exhaust smoke.
Terry
