the equivalent circuit (for transformer)
hello,
i'm familiar with the equivalent ciruit of a simple(ordinary) transformer(monophaze),but i have add a resistor between the two windings in order to be connected electricaly so i'm puzzled to which branch of the equivalent circuit this resistor do belongs .the second question is do this transformer keep its principle to work.
thanks in advance for your comments and help.
RE: the equivalent circuit (for transformer)
http://egweb.mines.edu/EGGN389/Lecture12.html
If you're not comfortable with per unit, then you need to include an ideal transformer in your model. That ideal transformer has no connections from priamry to secondary.
I believe you can simulate the ideal transformer with dependent sources. E2 (upstream of X2,R2) is proportional to Imagnetizing. I1 at input to ideal transfomrer (downsstream from magnetizing branch) is proportional to I2.
If you can clarify your question that may help.
