Sheet Metal - Jog not Flattening
I have some sheet metal parts that I made by:
Extruding a block
Shelling the block
Split at the corners
Converted to Sheet Metal for each side
Jogged the upper part to create a zero clearance flange
But when I go to "Flatten" that particular piece, the jog remains.
Is there something I am missing? Or is this just the way Jogs behave?
Extruding a block
Shelling the block
Devon Murray, EIT [Mechanical]
Solidworks 2011 SP 2.0
RE: Sheet Metal - Jog not Flattening
Turns out the "Jog" was suppressed under the "Flatten" feature at the bottom of the tree.
