small variable displacement pump
Hi all,
I am looking for a small (.5 cubic inche/ rev displacement) variable displacement piston pump.
3600 RPM, at 3300psi, synthetic hydraulic fluid, ISO32.
anyone familiar with a manufacturer and model that I might investigate?  I am presently perusing catalogs from Parker, Oilgear, and Eaton.  so far no dice, but if you have any leads there, I am all ears!
RE: small variable displacement pump
I don't know where you would find a pump that small for such a high pressure, but most of your pressure compensated piston pumps include a "max volume" stop option.  I know the Parker, Oilgear, and Eaton all include that option.  (Getting a smaller pump though would be more efficient).
