SW 2011 SP1 vs 2010 SP4
I could not justify the subscription service...so I let it expire. I was at SW 2011 SP1.0 when this happened. I currently have 2010 SP4 in use (64 bit on workstations, 32 bit on laptops).
I don't normally like to jump versions till at least SP2 or 3, to let the bugs get worked out....
What is the consensus? Is 2011 SP1 worth making the jump to?...or am I better off staying 2010 SP4 for a few years. There are a few features in 2011 I would like to have...like being able to better control hole wizard with configurations/design tables....
Thanks for your input....
RE: SW 2011 SP1 vs 2010 SP4
Thanks for the input. I can not get SW 2011 SP2. I have the ISO image for SW 2011 SP1. Once your subscription expires, you can only install up to the SP that was in place at the time your subscription expired. So I am really looking for input on 2011 SP1.
It is good to hear that your VAR endorsed SP0, however.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
Can you elaborate please?
Thanks.
The best and safest way is to do a dual install and test for yourself. Make sure you back up all your files before using SW2011 ... just in case you want to go back to SW2010.
And make sure all the new install folders are suffixed with 2011
https://forum.solidworks.com/docs/DOC-1014
