In Context Wonder Busted, Temporarily.
I made an in context wonder assembly. Almost everything was driven from a few assembly level sketches, and the length of an extrude. The parametric world obeyed me.
Then I assigned a material to all my parts, everything breaks, the parts are still there but the sketches & extrude length don't drive it anymore. Rebuild, top level rebuild, open the backup, still broke. I delete & rebuild a couple bodies, re-select an face for an end condition and it seems as OK as it needs to be.
What happened?
RE: In Context Wonder Busted, Temporarily.
Does this happen with regular (not in-context) assys?
Can you reproduce the problem on simple in-context assys?
